Is it possible to change power while cycling, from one number to another.
How big are the levels, 10W?
Change power
Re: Change power
If you have an interactive trainer and you are using our my e-training software or app, it is possible.
You have to select power mode if you use the app or the free ride mode in the software.
I confirm you that resolution is +/- 10W
