Arion Digital Smart B+ vibrating
alvarezkeko
My Arion Digital Smart B+ is vibrating on the two rear rollers, will it be the belt? Is there any way to maintain the drums?
Sergio Alvarez
Guerrero, Mexico
Guerrero, Mexico
Re: Arion Digital Smart B+ vibrating
It's more probable something on a drum.
Please contact the customer care at myetraining@elite-it.com.
Did you get a solution to this, I have similar
Guys,
try to move the single roll on its axis (not radial or tangential, just on its axis). It there is some space, you need to tie the screws once you remove the plastic black cover on the side
