I have been using my Elite Rampa and sometimes the cadence and speed seem to be a little inaccurate.
I was thinking of getting the Elite cadence and speed sensor. Would this be the best one or is there a better option? (i run everything through bluetooth)
My understanding is that the MISURO B+ will not work on the Rampa.
Many thanks
Elite Rampa - Best Additional Sensor
Re: Elite Rampa - Best Additional Sensor
Misuro B+ cannot be used with Rampa.
You can use our wired sensor (it's the cheaper choice):
https://www.shopelite-it.com/en/sensors ... sensor-kit
Otherwise, you can use any wireless ant+ or bluetooth smart cadence only sensor (which protocol to use depends on the device you use; if you usually work in bluetooth, a bluetooth sensor may be the perfect choice)
