WiFi Analyzer playing tricks on me
joeking22
Postby joeking22 » Sun Jul 12, 2020 7:28 am
I've been having issues with certain devices losing connectivity to the WiFi sporadically for the past year. All the devices are in different parts of the house. One is a laptop and one is a Roku. I do have smart phones as well, but I have unlimited data so I usually don't keep track whether I'm on WiFi or not to know if they were affected equally. kohi click test
So I go to check my WiFi channel to see if it's probably on a congested signal. When I do the initial walk around the house checking, it says channel 1 is the best choice for 2.4ghz, and 144 is the best for 5ghz. So I make the changes and go to test again. Now it's saying Ch 5 and 36 are the best, and Ch 1 and 144 are zero stars. Wtf? So I switch back and it did it again. So I truly have no idea how I've made a difference. What gives? Also, side note, there are multiple routers popping up on the big 3 (1,6,11) so I know it's not just the Analyzer picking up my one device and using that as a reason to say the channel is bad.
Any ideas?
Re: WiFi Analyzer playing tricks on me
Postby Elite Admin S » Tue Jul 14, 2020 10:58 am
Ant transmits at 2.4GHz, so if you use the same channel (or a channel that transmits on a frequency that it's one of its mulitple - upper or lower) you may have problems.
