Direto speed value too high on non-Elite device
Morby
Postby Morby » Sun Sep 24, 2017 9:06 pm
When pairing the DIreto to my Garmin Fenix 3 as a cadence/speed sensor, the speed value is way too high (roughly 5 times higher) than shown in the myETraining app. Cadence looks fine instead.
My guess is that it could be a matter of using a corrective factor for the wheel circumference. However, in the PDF linked in the sticky post on this topic, the Direto is not listed. Should this be the reason, could anyone please state the correct circumference value required for non-Elite apps/devices?
Thank you all for your help!
Re: Direto speed value too high on non-Elite device
Postby Elite Admin S » Mon Sep 25, 2017 10:06 am
I confirm you that you have to use a modified value for Direto if you use a non elite device.
In your case, you have to use circumference / 12.1 (soon we will update the table, sorry)
Morby
Postby Morby » Mon Sep 25, 2017 2:27 pm
No worries!
Thank you very much for your prompt reply!
