Oil volume and its characteristics in real turbo muin B +
staffak22ru
Hello! Please help with the repair of a real turbo muin b +. Start to drip a little oil from the bottom of the exercise bike. I want to replace the gasket, fill in new oil and seal everything with sealant. Tell me, what characteristics should the oil have and what should be its quantity for the correct display of power?
Re: Oil volume and its characteristics in real turbo muin B +
I am starting to have the same issue. Where can I get the gasket and oil characteristics?
I have contacted Elite and they said the trainer will work normally without oil so was left with that... no other support
staffak22ru
j2chau@gmail.com wrote:I am starting to have the same issue. Where can I get the gasket and oil characteristics?
It is strange that they answered that way. After all, oil creates resistance to the flywheel. I wrote in support of elite and they sent me a new oil and gasket for free!) The package has not yet arrived, but when it comes I will unsubscribe according to the result. I advise you to try to write to them.
Oil is fundamental in Turbo Muin.
But it's not so important in Real Turbo Muin.
In Turbo Muin, the oil guarantees the proper trainer resistance and uniformity. And adding the oil is an easy operation, with proper instructions.
In Real Turbo Muin, the resistance is due to the magnetic component (the fluid component is not relevant). The oil is used to have a more progressive resistance if you use the trainer in stand-alone mode (without the resistance control). But also there, it's not so relevant. As replacing the oil is not an easy operation, we suggest to continue to use the trainer even without it.
Elite Admin S wrote:Oil is fundamental in Turbo Muin.
Is there a way to still get a gasket, oil, and instruction considering the other person was able to get a kit?
We don't send oil gasket for Real Turbo Muin, only for the Turbo Muin (I suppose that the person above that suggested, has this model)
Folks
Oil has leaked out of my Turbo Muin Smart B+
Post above says it's possible and easy to replace oil in the Turbo Muin
Can someone please tell me where I can buy oil for this and instructions on how to refill
D
D
Elite sent me this video and the gasket but no oil.... so not sure where to find the oil or specs or even MSDS on it.
https://drive.google.com/file/d/0B_4_od ... NURkU/view
