i have problem connecting DRIVO II using ANT+ with ZWIFT on a Samsung S6 tab.
It connect using bluetooth but not using ANT+. Power meter and cadence connect fine using both bluetooth and ANT+.
Moreover using ERG chaning resistance is quite slow.
Thanks for help.
DRIVO II ANT+ ZWIFT
Re: DRIVO II ANT+ ZWIFT
Hi Carlo
Please contact the customer care at myetraining@elite-it.com
The guys will give you instructions to check reactivity and also to check the ant+ connection.
Users browsing this forum: No registered users and 167 guests
