Misuro sensor not connecting
vprou
Postby vprou » Fri Apr 24, 2020 2:27 pm
Dear Elite team
I had already tried some time ago with the help of your service to resolve my issue with the Misuro sensor: Sensor is seen by my Garmin edge device and connect if i push the inner button, but then the connection is lost when the sensor is put back in place and the data not transmitted.We checked wih your help on installation and so on, all fine, and so it never worked. I want again to try and solve it today in order to connect to Swift. Please advise if the replacement of the sensor could be a solution and if yes, how i can buy a new spare sensor.
Best Regards
Vincent
Re: Misuro sensor not connecting
Postby Elite Admin S » Mon Apr 27, 2020 5:26 pm
Hi Vincent
This forum is not meant to be a technical assistance channel.
It's ok if you look for suggestions or hints, but for replacement part and issues like this you have to contact our official customer (myetraining@elite-it.com)
Return to “Misuro”
