Hello
I used a translator. I have such a problem that only the central diode bluthooth is lit, I will run the tenezer once, I drove over and set it aside. Later I wanted to ride again and something like this happens.
Elite drivo not worka, the blue LED is on
damianpilat
Re: Elite drivo not worka, the blue LED is on
I use a translator
The problem is with the board I wrote to the elite and they have to send me a board
If only the blue led is on, the problem may be:
- on the power supply (that may not supply the correct current and voltage level)
- on the electronic board, that is not working properly
If you can, check the output of the power supply.
In any case, contact the customer care for a replacement of the power supply or the board
narax69278
Elite Admin S wrote:Hi guys
Hi buddy, was facing similar issue at my end. Thanks for the update on this.
Regards,
Ruben E Robertson https://tutuappx.com/ Vidmate
