I have a elite qubo digital Smart+ and I have a big problem, my watts are lower them there are in real life. How can I fix that? In Zwift program the maxim watts are 65/75w.
And I need some help to send my P1,P2,P3 to my PC.
Best regards
Carla
Elite qubo digital Smart+
Re: Elite qubo digital Smart+
If you have a not good simulation, it may be necessary to modify the three calibration values.
But in your case, it seems a different problem.
If you use my e-training app do you have the same problem?
If not, probably there's a problem with Zwift configuration.
If yes, there may be a problem on the trainer
Contact our customer care at myetraining@elite-it.com
