speed sensor - turbo muin smart b+
dkrieber
Postby dkrieber » Sat Sep 16, 2017 2:07 pm
I just got the turbo muin smart b+ and try to set it up with my Garmin 810. I really dont find the measurements given from the Misuro very accurate. cadence constantly shift +-10 rpm, same with Watt) I use my garmin cadence sensor instead and there is no problem with cadence measurement. Now I have problem with the speed. It is ridicules low, like around 0,5 km/h. I made a test ride for 45 mins. and all I got was "moving" was around 200 meters :lol:
What is wrong with the speed?
Re: speed sensor - turbo muin smart b+
Postby Elite Admin S » Mon Sep 18, 2017 8:45 am
Are you sure to have put the correct circumference value? For example, if your trainer serial number is higher than 30000, you have to put a circumference value of : circumference/13.2
Please check this table and be sure to have put the proper value (third column, non elite app/devices - connection as a speed/cadence sensor):
https://drive.google.com/open?id=0By4rZ ... 2kwUC1tUzg
dkrieber
Postby dkrieber » Mon Sep 18, 2017 4:47 pm
hi,
yes, serial number is +50000. Circumference is set to 158 mm in the Garmin.
dkrieber
Postby dkrieber » Tue Sep 19, 2017 7:34 pm
so what now? any answer?
Postby Elite Admin S » Wed Sep 20, 2017 10:07 am
Sorry for the delay, as written in the regulation of the forum we cannot answer daily here (if you need a quick answer, I suggest you to contact the customer care directly).
The circumference is correct. It is necessary to investigate further.
Please contact the customer care at real@elite-it.com and the guys there will help you to find the cause of the issue
frodeasen
Postby frodeasen » Tue Oct 27, 2020 8:37 pm
if u change to 8,8 instead u get more ok speed as if u ride a all flat stage, it almost match stravas flat courses with speed and distance
2096/8,8
