Shift Lever not working
fabriciomacedopb
Postby fabriciomacedopb » Wed Apr 01, 2020 12:33 pm
Hello, I have a Qubo power Mag smart +. The shift Lever is not working. I bought the product in 2017 is out of warranty and I have no authorized center probably 2000 km from my city. Can you send a disassembly and assembly guide for the shift Lever?
cse256
Re: Shift Lever not working
Postby cse256 » Tue Apr 07, 2020 5:35 pm
I have the same problem
cse256
Postby cse256 » Tue Apr 07, 2020 7:01 pm
In my case, the little stop near the screwdriver doesn’t work properly on the little cilindrial spring, unfortenately I dissambly all the knob, with it’s epicicloidal mechanism and and the big round spring, now I m trying to mount in the correct way, may be some wd 40 on the assembly would have work :shock:
kindaliker
Postby kindaliker » Thu Jul 23, 2020 12:27 pm
cse256 wrote:In my case, the little stop near the screwdriver doesn’t work properly on the little cilindrial spring, unfortenately I dissambly all the knob, with it’s epicicloidal mechanism and and research paper examples about it and the big round spring, now I m trying to mount in the correct way, may be some wd 40 on the assembly would have work :shock:
Good job from you. Did you fix it? wd 40 is working ok?
Sobamee
Postby Sobamee » Fri Nov 19, 2021 8:18 pm
Did you guys found a way to fix it?
paxtonleiny
Postby paxtonleiny » Thu Jun 15, 2023 3:12 am
cse256 wrote:In my case, the little stop near the screwdriver doesn’t work properly on the little cilindrial spring, unfortenately I dissambly all the knob, with it’s epicicloidal mechanism and and the big round spring, now I m trying to mount in the correct way, may be some wd 40 on the assembly would have work :shock:
I applaud your efforts. Is it working now? The WD-40 is fine, right?
Postby Elite Admin S » Wed Jun 21, 2023 8:33 am
Please contact our support before disassemble a trainer.
We can give you instructions and tell you what you can do by yourself and what needs special equipment.
Here you can raise your ticket, we reply usually within 1 day:
Return to “Smart Trainers”
