I have an old RealTour Ant+. I and struggling to get it working with Zwift. Is it even possible?
I don't think I am able to do a firmware upgrade on this model.
FA
Old RealTour ANT+
edward.simpkins
Re: Old RealTour ANT+
Yes, i've had mine working in the past and the Zwift compatibility site lists it as working:
https://zwift.com/hardware?utm_source=g ... EiEALw_wcB
fazloen.armadien
Thank you for your reply. I can connect to Zwift initially but then the connection drops.
