Greetings!
I am thinking about purchasing an Argon18 Gallium Pro Disc
https://www.argon18bike.com/en/bikes/ro ... disc-gloss
It has 12X142 spacing. But a custom thru-axle and frame-design
Do any of your trainers work with bike-specific axles?
I cannot use a skewer-style axle.
I need to use the system provided by the frame.
thank you!
THRU AXLE COMPATIBILITY
Re: THRU AXLE COMPATIBILITY
Your bike is compatible with all of our latest Direct Drives (Direto, Drivo, Kura, Turno).
It is also compatible with Real Turbo Muin thru axle version and Turbo Muin thru axle version.
Finally, if you want to use a traditional trainer (with the frame) it is necessary to buy our specific adapter.
Gavin1smith
Can you use thur-axle adapter on rampa?
I confirm you that you can use the thru axle adapter on the Rampa frame.
