Elite Qubo Fluid vs Elite Qubo Power Fluid? Measures Power with Misuro B+
redhot
Postby redhot » Wed Feb 22, 2017 4:24 pm
Hello
Can you tell me please the diference between a "Elite Qubo Fluid" and "Elite Qubo Power Fluid" ? They are different? Or are the same product?
Can you tell me also if it's possibble to measer power (w) with this trainers and a Misuro B+ ?
Thank you
Rui Duarte,
Portugal
Elite Admin M
Re: Elite Qubo Fluid vs Elite Qubo Power Fluid? Measures Power with Misuro B+
Postby Elite Admin M » Thu Mar 09, 2017 11:18 am
It's the same trainer.
If it is the misuro compatible version, you can use the Misuro on it to have the transmission of power.
But the power value is only calculated from speed, the Misuro is not a power sensor.
chenkahshan
Postby chenkahshan » Sat Aug 12, 2017 5:43 am
Hi, I thought there are different? In my eTraining and other 3rd party app, both trainers are available to select and it is pretty obvious that their virtual power curves are different. Please enlighten us, thanks
Postby Elite Admin S » Mon Aug 28, 2017 8:30 am
They have a different roller diameter and a different power curve (power fluid is more powerful).
The Qubo Fluid it is available only in USA, also.
Users browsing this forum: Baidu [Spider] and 23 guests
