Real Turbo Muin B+ configure PA and PB
lap3520
Postby lap3520 » Sun Sep 10, 2017 1:28 pm
Does any one know how to configure PA and PB in a "Real Turbo Muin B+"?
I Followed the guide on the Elite Home Page that state you can configure these values in Real software under “Settings” – “Resistance Unit Calibration”. Only in version 7.2.0.77 you can only set one value between 0,5 and 1,5 ... not PA and PB. I am confused????
So I tried to connect to me trainer with the myETraning app via Bluetooth, and can get to the Advanced Settings where the PA and PB values are located - only when I change them and store the the app fools me to believe it will store the values, but if I read them back again, they were not changed???
Any ideas are welcome - it is a bit frustrating to see between 4-600 watt on the display during an easy warmup
Re: Real Turbo Muin B+ configure PA and PB
Postby Elite Admin S » Mon Sep 11, 2017 9:33 am
The two values of Pa and Pb can be found on a label on the trainer.
When you change them in the app, the app will send those values to the trainer.
When you reopen the app, the values shown in the menu are the default values, not the latest values you've inserted.
So, please check your Pa and Pb values, insert them in the app and try again using the app/software.
If you still have wrong power values, please contact our customer care at real@elite-it.com explaining the situation
Thelma Viaduct
Postby Thelma Viaduct » Fri Feb 21, 2020 11:40 pm
My PA is 129, PB 303
After a 90 min session on Zwift, my Average power is 155W using Elite Real Turbo Muin, but 149W on my Stages Crank.
What should I change my PA and PB to to make up that 6W difference?
PA 135 or PA 123???
At 200W Elite Muin, my Stages is 187W to 190W average.
I have tensioned the belt bolt on several occasions.
staffak22ru
Postby staffak22ru » Tue May 19, 2020 9:58 am
Thelma Viaduct wrote:My PA is 129, PB 303
PA 135 or PA 123???
Hello! Have you figured out your PA and PB values? What belt tension did you use to make the power readings match your power meter?
Thelma Viaduct
Postby Thelma Viaduct » Tue Nov 10, 2020 12:06 am
I am still adjusting to match my power meter. The calibration is useless.
Please can you upgrade the firmware to make erg mode faster.
Return to “Real trainers”
