Elite Direto set up
Thenewbs
Elite Direto set up
Postby Thenewbs » Thu Jan 16, 2020 5:41 pm
Hey Guys and Gals.
I'm new to this.
Just bought a Elite Direto, Got A window 10 Laptop with ANT+ dongle plugged in to it. Zwift App installed and membership purchased but not activated yet, still using the free month trial until i work out the teething problems.
Couple of things.
When I ride it will says top left corner of Zwift app in going 37kmh and if i stop and start again it says 9kmh and i'm pedaling the same.
I downloaded the elite App to try and calibrate. Selected the Direto and click next and it advances to next screen but tells me i still need to select trainer. Can i calibrate it through the Zwift app ?
Also when i am up and riding the WiFi light still flashes on the trainer. Is this because i'm connected with the ANT dongle.
Any advise you can give would be great.
Look forward to your reply's.
Thanks Ken
ivan.salalon
Re: Elite Direto set up
Postby ivan.salalon » Fri Jan 17, 2020 9:28 am
Olvidate de la velocidad en ZWIFT dado que es un valor que calcula el simulador no tu rodillo. Es decir, hay muchos factores que actuan, terreno del simulador, tu peso, altura y tus vatios.
Espero que te sirva de ayuda.
Un saludo
