Hello everyone,,
Have just completed a myrealvideo workout and tried to export it to Strava, initially via the direct export, and then by uploading the TCX. When I did so both ways I ended up with strange data. Distance was correct, but time showed as 8mins as opposed to the 34mins it actually took me. The speed data was also incorrect showing an average of 80+kmph and max of 100kmph. Clearly something not working right. Tried uploading the TCX to mapmyride as well to verify if it was a Strava issue however got the same result.100001.onl/ 1921681254.mx/ acc.onl/hotmail
Previous exports to Strava have worked fine so not quite sure whats going on with this time.
Checked the CSV file and the data appears to be correct.
Ta
drake.
Export to Strava/TCX export
Re: Export to Strava/TCX export
It's not a Strava issue. I think it's the same bug I told Elite almost 2 years ago. 8 minutes is the length of the video.
But this way you can get lots of KOMs!
I see the same thing 80+ max, I imagine they will correct that in the future.
I just imported to Garmin and have the same thing 80.5 mph max. I'll just have to edit the data, better than having to input it all.
