Turbo Muin vibrations
brianppbyrne
Postby brianppbyrne » Tue Nov 26, 2019 1:42 pm
I have just purchased a new Elite Drivo Direct Drive Smart Turbo Trainer (1) to replace my Turbo Muin S/N 33365 Code 0135002.
My Turbo Muin had started to vibrate and so I decided to replace it with the Drivo.
On inspection of the Turbo Muin I noticed that the small black plastic roller had deformed, not longer round.
Can this roller be purchased with or with the bearing.
Also, can the belt be purchased and it would be helpful if it could replace the silicone drive fluid.
Thank you in anticipation.
Kind Regards,
Brian
Return to “Turbo Muin”
