Direto resistance doesn't change with slope?.
iosman
Postby iosman » Sat Oct 26, 2019 8:53 pm
My direto stopped changing resistance as a result of changes in the slope.
I just paired the direto to zwift on my macbook mini and my iPhone and to FulGaz on my iPhone and my iPad. Regardless the configuration, the Direto resistance remains constant no matter what the slope on zwift or FulGaz is. Absolutely no change. However, when doing training on zwift using ERG mode the resistance changes properly to match and maintain the watts. ometv chatroulette Therefore, is seems to be a problem with the command the unit is receiving when the slope is changing.
thanks
iosman
sr
Re: Direto resistance doesn't change with slope?.
Postby sr » Mon Nov 04, 2019 3:05 pm
Have the same problem on DiretoX- any solution?
sottole3
Postby sottole3 » Sat Dec 21, 2024 3:34 pm
Same issue with Zwift! Someone can help me?
marek.zelek
Postby marek.zelek » Sat Jan 04, 2025 10:24 am
Yes, I have the same after upgrading to the latest version of firmware. Initially I thought it was the Zwift issue, but I tried the Elite app and the resistance remains flat when I adjust it on the app. Defo a trainer issue, either firmware or mechanical... I hope this can be fixed!
steve.hammatt
Postby steve.hammatt » Sat Jan 04, 2025 10:28 am
If the trainer resistance does not change when you use Level Mode in the myEtraining app and manually change resistance there, then you need to raise a ticket with Elite support - https://support.elite-it.com/en/ticket
