I’m new to the Suito and My E Training but can’t figure this out.
I’ve got my Garmin set up to receive the data from suito as a sensor and it works perfectly. However on the my E Training app the distance is double what it should be even though the speed is say 35kph for the hour it’ll read about 70km covered??
The really weird bit is on the Garmin it reads it as 35kms covered?
It’s not a massive deal but I can’t export from the app as it’s on drugs!
Distance covered way too high but speed and cadence is correct???
d4vidmcinally
Re: Distance covered way too high but speed and cadence is correct???
Same issue here. Speed seems reasonable but avg. speed x time is much less than distance claimed. This is the same behavior regardless if video or maps courses are used.
I checked my zumo trainer and app for updates but both are on the latest version.
Hi, i just have the same problem. Have you got allready a solution,
With kind regards,
With kind regards,
