Hello, I have a couple of questions I'm not able to find the answer to.
Do I need to unplug the power cord on the Qubo Digital Smart B+ when I'm not using it? If I leave the unit plugged in does the unit go into sleep mode when not in use and powers up when the roller is spun?
Thank you.
Inside Ride E-Motion Rollers with Elite Qubo Digital Smart B+
jadamsmtb@gmail.com
Re: Inside Ride E-Motion Rollers with Elite Qubo Digital Smart B+
The trainer goes to stand by mode if you stop pedaling, so it is not necessary to unplug the power.
But it is always a good habit to remove it to avoid problems if a storm arrives.
