Bkool Drivo compatilility ?
roberthorrocks
I have a Drivo trainer (excellent by the way).Is it compatible with Bkool Simulator software?
Re: Bkool Drivo compatilility ?
Yes, I confirm you that it is compatible
roberthorrocks
Thanks for the reply ...Cheers
Sorry , but i cannot get it to work . I will wait for Zwift on android .
Hi , back again . Had another go - it worked !
Embeddeddna
I’ve got a drivo2 and I would use bkool but speed on simulator is too fast. Is there a solution for it?
I have Drivo II and why it is not in the list, when I want to connect it in the application Bkool?
There is only Drivo (1st gen)... So I feel that it is not compatible with the app.
andiyatsia
roberthorrocks wrote:Thanks for the reply ..audacity find my iphone origin .Cheers
