calibrate power meter on Real Power
I am using zwift and I am not able to use any of the higher gears. I don't trust that my watt readings in Zwift are correct. Can I calibrate the Real Power trainer?
ryanfledelius
Re: calibrate power meter on Real Power
did you find a solution?
I have the same problem
