Trainer Muin Speed Descrepancy
Hornsbeef81
Postby Hornsbeef81 » Mon Apr 15, 2019 6:32 pm
Hi.
My trainer muin (which I bought from a close friend) has been demonstrating the usual power issues (Too much resistance and too high power reading) But the other day while linking to my Garmin Edge 1000 or the first time, I conducted a calibration as instructed. After this was concluded I began my ride. Only to see that with a very low cadence of 50rpm, I was developing a speed of 148mph! Try as I may, I couldn't get this to change, I attempted further calibrations and even adjusted the belt tension but no change.
Help!
Re: Trainer Muin Speed Descrepancy
Postby Elite Admin S » Tue Apr 16, 2019 11:29 am
Calibration is not available if you use a Turbo Muin (or maybe do you have a Real Turbo Muin instead?).
The speed issue is due to wrong circumference setting, instead.
In fact, in your Garmin you have to insert a circumference value that consider also the internal ratio of the trainer.
If you have a Turbo Muin with serial higher than 30000, you have to insert a circumference value equal to your real wheel circumference divided by 13.2.
See this table for reference:
https://drive.google.com/open?id=17rxcz ... ogPySELXTA
iosman
Postby iosman » Sun May 26, 2019 9:23 pm
Love your blog man. Thanks for this stuff.
https://www.tweakbox-app.co
https://www.tweakbox-app.org
https://www.tweakbox.biz
