Elite Crono Fluid and a Misuro B+
Andytizer
Postby Andytizer » Sat Jul 22, 2017 5:10 pm
I recently bought a Elite Crono Fluid and a Misuro B+. I'm trying to install the Misuro B+ but it doesn't seem to be taking any readings - in the app it asks me to pedal but no readings.
I tried to follow instructions: stick the unit near the roller, press the button 5 for Power Fluid trainer. I couldn't find a place to put the little magnet - I can't open the cover to the roller. What am I doing wrong?
Re: Elite Crono Fluid and a Misuro B+
Postby Elite Admin S » Mon Jul 24, 2017 9:09 am
Not all the Fluids are compatible with Misuro.
The first productions started before the misuro production, so not all the trainers have the magnet housing.
Check if the trainer box has a "misuro compatible" label. Also, check if there is the magnet housing on a side of the elastogel roller (you should see the two screws).
If your trainer is not misuro compatible, go to the shop and explain the situation (they have given you a not compatible configuration).
You may ask for a misuro compatible Fluid or you can return the Misuro B+ and use a speed&cadence sensor to connect with the app instead.
If you have any problems, contact our customer care at real@elite-it.com and we will help you.
Return to “Misuro”
