I have an Elite Muin (S/N 10227) and the Misuro B+ sensor. I've set the Misuro to 3 led blinks and the wheel circumference to 2070mm. I am using the upto date e-training app on an iPhone. The power reading it gives seems less than half what I would expect. It would be hard to get it above 100W for more than a few minutes. I'm honestly not that bad. Using a powertap rear wheel the other day I had a pretty easy ride of about an hour and a half averaging around 200W. Is there anything I can do?
Thanks for any help, Phil.
Elite Muin and Misuro B+
Re: Elite Muin and Misuro B+
Hi Phil
First a little note: you don't have to compare the behavior of the trainer with what you experience on an outdoor training.
The Turbo Muin is not a simulator, its power curve grows faster than on road.
I'll do an example to clarify this point.
Suppose to ride on road with a 0% slope. At 30km/h you'll probably have a power of around 130 - 150W.
If you ride on Turbo Muin at the same speed, you'll develop more than 400W.
That said, it is also possible that the trainer is too hard as 100W is a feasible power.
Do you hear any strange sound while you're riding?
The pedaling is smooth?
hayward_phil
Thank you very much for replying.
The pedaling is smooth. There are no strange sounds. I use my race bike which is very well maintained.
I wouldn't compare power at speed at all on the trainer. I wouldn't even look at speed. What I'd compare is the effort I perceive against the power. My hope was to be able to estimate my FTP then train accordingly but the figure is far too low to be useful. Regardless of speed I can easily maintain more than double the power on the road than I would do on the trainer. That can't be right can it?
At this point, it is better to contact our customer care to investigate further.
Please use the contact form in the app, so we will receive all the data related to your device.
Add also a link to this conversation and remember to specify the serial number of the trainer.
