I do get the Qubo Smart+ connected - so my dongle works on my MacBook Pro, but E-trainig doesn't recognize my Sigma Combo Sensor anymore - it used to do so.
How do I fix this, or is it a bug in the latest E-training software?
No connection with Sigma ANT+ and E-training
Re: No connection with Sigma ANT+ and E-training
Did you check the battery level on the Sigma belt?
Try also this:
- remove the battery from the belt
- restart your mac
- run my e-training
- put the battery on the belt
- do again the configuration
If still it doesn't work, contact our customer care at myetraining@elite-it.com
Try also this:
- restart your mac
- run my e-training
Users browsing this forum: No registered users and 124 guests
