Zumo Calibration Failed
samuel.mundula
Postby samuel.mundula » Mon Feb 25, 2019 2:08 am
Hello, I did the procedure as listed (rode for >10 minutes) then went to the program on my laptop & went to the calibration menu. It asks me to start pedaling, then pedal faster, then stop pedaling until it spins down - then after the trainer spins down completely it says calibration failed.
Any ideas? Any way to calibrate this? Thanks
wmscyclone@yahoo.com
Re: Zumo Calibration Failed
Postby wmscyclone@yahoo.com » Wed Feb 27, 2019 7:22 pm
I can verify that I have completed calibration twice on my Zumo using the iPhone app.
Both times were after rides of approximately one hour. Then I did the spin down calibration from advanced configuration in the app.
If you have an iPhone or Android you could try the app and see if the calibration works there.
Good luck!
natetg57
Postby natetg57 » Tue Mar 05, 2019 7:06 pm
With my windows computer running Rouvy software, I had to try 4 or 5 times to get a successful calibration.
Postby Elite Admin S » Tue Mar 12, 2019 12:47 pm
If calibration fails more time in a raw, contact our customer care at myetraining@elite-it.com.
regards
markcowell23
Postby markcowell23 » Tue Sep 10, 2019 10:37 am
facing same issue :(
alexhall
Postby alexhall » Wed Nov 20, 2019 6:39 pm
I ran the upgrado app to get the latest firmware, ran the calibration test, it failed (several times) on both PC and Android App, now my resistance fluctuates between low and high in what seems a cycle. It seems that the whole thing is now fried as I ran a test ride in the myetraining app and achieved 3500 watts spinning a high gear at no resistance.
