Very high resistance independend from App
Claus
Postby Claus » Mon Feb 04, 2019 11:04 am
I use the Direto some time already and in the past everything was fine. Recently I have the problem of a very high resistance (like maximum? ) all the time. Whatever App I use (myETraining or Zwift or ..) the resistance stays a maximum. I tried to calibrate but even at calibration the restance stays high. Sometimes after diconnecting the trainer from mains and reboot the system it works for some minutes before it gets back to high resistance.
Does anyone have the same issue? Is this a software problem (on iPad or internal) that can be solved easily? At the moment the trainer is more or less useless unfortunately.
Thank you very much for your support.
Best regards
Claus
Users browsing this forum: No registered users and 63 guests
