I keep having issues with my Direto and Zwift: If I connect the Direto to Zwift (BT or ANT+, result is the same), the resistance is very high and goes up and down. On a flat road, it will force me up to 400w, release, force up, etc. I cannot ride in Zwift with resistance control. As a result, I use the Direto in level mode (level 3), controlled by my Wahoo Elemnt, and use my power2max power meter for power data.
This did not use to be the case: initially, everything worked fine (Nov to Dec 2018) - I was able to ride courses and do workouts in ERG or level mode. Then, I had a phase where there was too little resistance (spinning out on the flat: 52-11, >100rpm, <300w). Now the resistance is high and random.
It seems that I am not the only one with these issues, there is a topic on the Zwift forums, too: https://forums.zwift.com/t/current-issu ... s/27492/32
Can you please help? I am really lost for how to fix this!
Settings:
- Zwift on Win10, latest version
- ANT+ dongle - works fine, no data drops
- Direto connected under FE-C profile for controllable trainer
- I tried to set the circumference in MyETraining on Android and Windows as 2086, but the app shows 173
- I also have
Other symptoms:
- If I try to do a spin down calibration in Zwift, the speed stays at 3kph, even if I sprint in 52-11.
- The trainer resistance is correct in Wahoo Elemnt if I go to "level" mode. If I go to "passive" mode, it starts pulsing, even when NOT connected to Zwift
- There is a difference of about 20w (relatively constant) between my power meter and Direto reading - it seems to be only when used in Zwift
Continued issues with Direto and Zwift
Re: Continued issues with Direto and Zwift
I'm curious about this as well - but with The Sufferfest.
I am unable to use the Direto XR in ERG mode - resistance in W specified by either a Mac Laptop, iOS app, or a variety of head units. In any of these cases the resistance will skyrocket and basically become unusable.
Specifically, see the thread here:
https://forums.zwift.com/t/current-issu ... s/27492/79
So - what is the best way to set up an Elite Direto for Zwift and/or Sufferfest and/or a training plan via Garmin or another head unit?
Thanks,
Rod Diaz.
Thanks,
Rod Diaz.
emreertuna
Hey! I have the same problem and can't find a solution online. Submitted ticket to both elite and zwift but no answers yet. Did you find any solution? If yes can you please share? Thanks!
