I'm using Direto and it worked fine for a while. Since some time the resistance is more or less a maximum independend from the running APP on my iPad. I tried with myEtraining and Zwift. I can hardly run at lowest gear. Sometimes after rebooting the trainer it works for some minutes at standard resistance before it gets back to maximum.
Is this known and does a solution exist?
Thank you.
Best Regards
Claus
Very high resistance independend from APP
Users browsing this forum: Bing [Bot] and 59 guests
