Hello
I own the aleno smart.
In order to train on Zwift, I'm looking for a correlation chart of the 8 levels of resistance versus elevation.
Level 1 = flat
Level 2 = ....%
Level 3 ...
thank you in advance
Table of correspondence of the 8 levels of resistance
AaronAiidan
Re: Table of correspondence of the 8 levels of resistance
It doesn't work in this way.
Slope simulated depends on these factors:
- power
- speed
- weight
So, depending on the speed you're riding on the trainer, power will change and so the simulated slope.
- power
- speed
- weight
