for the last month I have a new Qubo Digital smart b + trainer, unfortunately I do not feel the resistance of the trainer, on the zwift it generates a lot of watts easily, I am not tired of riding uphill, it overcomes everything quickly and easily. I changed in the configuration of the trainer p1 (162), p2 (171), p3 (140) (I'm a woman, 42 years, weight 66kg), but it did not help much, the vapor dropped a bit, but driving is easy. I have the impression that I do not travel effectively on this equipment. I do not know what else I can do to feel this resistance - maybe he is mechanically disabled. Please help.
NEW Qubo Digital smart b + no resistance :( :( :(
magda.wloc@wp.pl
Re: NEW Qubo Digital smart b + no resistance :( :( :(
I have the same problem..
Did you already found a solution?
For this kind of issue, contact the customer care at myetraining@elite-it.com.
We will ask you some test to understand if there's a problem on the board.
Elite Admin S wrote:For this kind of issue, contact the customer care at myetraining@elite-it.com.
do not feel the resistance of the trainer, on the zwift it filezilla uc browser rufus generates a lot of watts easily, I am not tired of riding uphill, it overcomes everything quickly and easily. I changed in the configuration of the trainer p1 (162), p2 (171), p3 (140) (I'm a woman, 42 years, weight 66kg), but it did not help much, the vapor dropped a bit, but driving is easy. I have the impression that I do not travel effectively on this equipment.
andiyatsia
greeneyelevin
Hi, I have had a Qubo Digital smart b + for two years now, unfortunately for the last two weeks I have been getting the same problem.
On Zwift with hardly any effort I'm generating my usual watts, but I'm in my highest gears. I'm only turning at around 40-50 rpm & 100bpm - I'm not even breaking into a sweat! If I do put some effort in, I smash my usual segment times as the Watts go through the roof!
Although I've never calibrated the trainer I don't understand why its changed to this in the passed few weeks?
I tried changing the P1, P2 & P3 last night but it made no difference.
Steve
Steve
