I've just bought the Elite Quick motion rollers.
If I were to buy and add the misuro b+ unit
i) what setting should I use, number 1 generic rollers or 8 parabolic. From searching I think the answer is 1 but as the rollers are parabolic and from Elite would wonder why it should be set as generic.
ii) Once set-up correctly what repeatable measurements should I be able to receive on an Android phone running the Elite app. Speed and Cadence? If so how is the cadence measured?
Mike
questions on misuro b+ and quick motion rollers
dwtrux@att.net
Re: questions on misuro b+ and quick motion rollers
I use Setting 1 and that is what Elite recommended for QM and Misuro B+ with My E Training App on my iPad. However, that setting did not work to move the rider in Zwift and you would have to use setting 8 but the numbers were off.
As far as what readings on Android, I can't answer as I use the iPad.
