I have an elite crono trainer, it is second hand and it didn't come with any cable or external device. So I am trying to make it work for zwift(even if it does not work with zwift, I want to change resistance setting to match zwift criteria for calculated power)
I found an adapter with 12V ~ 1.5A output and it seems like working, but I couldn't connect using ant+ or bluetooth. There is a telephone plug input on the device but I couldn't find what to do with it.
I believe my device is this -> https://www.fawkes-cycles.co.uk/10533/p ... ainer.aspx
Any information about what and how to do something is useful for me at this point. I am also adding an image of the trainer.
Thanks in advance.
Elite crono emag inout trainer - zwift connection
- 07f27360-23eb-48a6-9417-82bfc01e0e0c.jpg (199.96 KiB) Viewed 6685 times
