HEART RATE SENSOR
doranspharmacy
HEART RATE SENSOR
Postby doranspharmacy » Sat Dec 29, 2018 10:59 pm
i HAVE TRIED TO CONNECT MY SUUNTO HEART RATE SENSOR TO THE MYETRAINING AP BUT NOTHING HAPPENS. I SELECTED PARAMETERS, THEN ADVANCED CONFIGURATION.THEN I SELECTED HR SENSOR SERIAL SENSOR TYPE SELECTED WAS ANT+. THEN THE SCREEN JUST STAYS ON " UPDATE IN PROGRESS".
HOW LONG DOES THIS PROCESS TAKE? CAN YOU OFFER ANY SUGGESTIONS ON HOW TO PAIR THE SENSOR.
MANY THANKS FOR ANY ADVICE AND GUIDANCE.
cONOR.
Return to “Rampa”
