Electricity build up with quick motion
Jerome
Postby Jerome » Wed Dec 26, 2018 1:44 pm
Hi !
I got a set of Quick Motion rollers for Xmas which I tried this morning. After a few minutes I managed to ride them with both hands, so it is not as difficult as I was expecting, but I have a problem with static electricity building up while riding and everytime I touch the metal garage door I get a chock.
I was thinking about buying an antistatic wrist band to earth myself. Will it work ?
Cheers
Jay
edwardphrase
Re: Electricity build up with quick motion
Postby edwardphrase » Thu Feb 21, 2019 4:12 am
How bad is the shock? If you wire your bike or wrist to the aluminum door, it will provide a circuit to continuously discharge .
Postby Elite Admin S » Tue Mar 12, 2019 12:32 pm
Humidify the room a little (this should help).
Also try changing your clothes and the tire ;)
Jerome
Postby Jerome » Tue Mar 19, 2019 6:05 pm
Hello !
Thanks for your help. I got myself a cheap antistatic wristband and the problem is solved.
Cheers?
Jay
Return to “Other Trainers”
