Quno Fluid + noisy roller
Questions on how to use this forum
rooksmith+@gmail.com
Postby rooksmith+@gmail.com » Fri Dec 21, 2018 5:16 pm
Is anyone monitoring the forum?
I have technical support questions:
1 How can I maintain the Qubo Fluid Plus - It seems to make ecessive noises.
2. Can I grease it somehow?
3. Is there a user manual, and a technical manual
Please check this video I made of the problem
https://youtu.be/FS4m15YcBuU
Doug Smith
Jeanette
Re: Quno Fluid + noisy roller
Postby Jeanette » Thu Feb 21, 2019 12:22 am
Hi Doug,
I know nothing but that sounds awful!
Try getting in touch with the support people through the contact section
on the Elite website homepage. They got back to me very quickly when
I needed to know if my bike was compatible.
Good luck.
Jeanette
Gladys26
Postby Gladys26 » Fri Mar 29, 2019 6:10 am
Yes i agree with above reply..U should contact officials..They are too quick in reciprocating u.They will definitely help u
StevenBShephard
Postby StevenBShephard » Fri Jul 19, 2019 9:03 am
What a good post you have shared this for us and I think you have to use a perfect value as the online assignment help uk use for this. It is a well written post which give many important links to users.
jobstart
Postby jobstart » Sun Sep 01, 2019 8:14 pm
Yes i agree with above reply..U should contact officials..They are too quick in reciprocating u.They will definitely help u surveyforcustomer
jobstart
Postby jobstart » Sun Sep 01, 2019 8:15 pm
I needed to know if my bike was compatible.krogerexperiencee
Return to “Forum questions”
