Quno Fluid + noisy roller
rooksmith+@gmail.com
Postby rooksmith+@gmail.com » Fri Dec 21, 2018 5:16 pm
Is anyone monitoring the forum?
I have technical support questions:
1 How can I maintain the Qubo Fluid Plus - It seems to make ecessive noises.
2. Can I grease it somehow?
3. Is there a user manual, and a technical manual
Please check this video I made of the problem
https://youtu.be/FS4m15YcBuU
Doug Smith
Jeanette
Re: Quno Fluid + noisy roller
Postby Jeanette » Thu Feb 21, 2019 12:22 am
Hi Doug,
I know nothing but that sounds awful!
Try getting in touch with the support people through the contact section
on the Elite website homepage. They got back to me very quickly when
I needed to know if my bike was compatible.
Good luck.
Jeanette
Gladys26
Postby Gladys26 » Fri Mar 29, 2019 6:10 am
Yes i agree with above reply..U should contact officials..They are too quick in reciprocating u.They will definitely help u
jobstart
Postby jobstart » Sun Sep 01, 2019 8:14 pm
jobstart
Postby jobstart » Sun Sep 01, 2019 8:15 pm
Return to “Other Trainers”
