My E Training - None Stop crash Drama
thomaskenyon
Postby thomaskenyon » Sun Dec 16, 2018 5:11 pm
application doesnt work... crashes everytime i try and use the application.... any ideas?
Re: My E Training - None Stop crash Drama
Postby Elite Admin S » Thu Feb 07, 2019 1:48 pm
Try uninstalling and installing again the app.
If the problem persists, contact the customer care at myetraining@elite-it.com
rosejsrhill
Postby rosejsrhill » Tue Apr 16, 2019 3:13 pm
I`ve got the same problem uninstalled and reinstalled twice still not working , I am running windows 10 does that make a difference ?
Steve H
Postby Elite Admin S » Thu Apr 18, 2019 9:09 am
@rosejsrhill,
contact the customer care you as well, it's necessary to investigate further
jensy
Postby jensy » Tue Jul 02, 2019 10:47 pm
rosejsrhill wrote:I`ve got the same problem uninstalled filezilla uc browser rufus and reinstalled twice still not working , I am running windows 10 does that make a difference ?
Steve H
moltoviaxx
Postby moltoviaxx » Thu Jul 04, 2019 4:16 pm
What formats will the files be exported from this app? how will they be stored on my ipod touch?
And are these files then able to be uploaded to garmin connect or strava?
Tutuapp 9apps Showbox
lankydwarf
Postby lankydwarf » Thu Nov 19, 2020 2:53 pm
Any update on this ? I have the same problem on a windows 10 laptop. Ive uninstalled several times and still the same, it loads and goes to the Setup screen within the app then just closes.
So frustrating when you spen £850 on a new trainer then the crappy piece of software wont work and the support is rubbish !!!!
If this cant be fixed might take it back and exchange for a Saris !
thomas.m
Postby thomas.m » Sat Nov 21, 2020 8:13 pm
Tragisch wie viele Nutzer das selbe Problem haben !!!
Neu installieren nützt nichts, nach der ersten Konfigurationsseite schliesst das Programm immer wieder...
Dazu kommt auch immer die Meldung das die Datei ungültig sei...
Für diese Preisklasse doch schon recht schei..e
Tragico quanti utenti hanno lo stesso problema!
Reinstallare è inutile, dopo la prima pagina di configurazione il programma si chiude sempre di nuovo...
Inoltre c'è sempre il messaggio che il file non è valido...
Per questa fascia di prezzo già abbastanza mer..
Tragic how many users have the same problem !!
Reinstalling is useless, after the first configuration page the program always closes again...
In addition, there is always the message that the file is invalid...
For this price range already quite sh..
awauters458
Postby awauters458 » Sat Nov 21, 2020 9:46 pm
Idem ne fonctionne pas.
Je viens d'acheter un nouveau Turno et d'installer l'app sur mon pc mais dés que je veux l'ouvrir elle cesse de fonctionnerdirectement!
davide_pantarotto
Postby davide_pantarotto » Sun Nov 22, 2020 5:41 pm
Hi all, I just managed to make the app work on Windows10. the step I followed, maybe it will work for you:
1) unistall from PC
2)remove from C:\Users\"user_name"\AppData\Roaming the folder named MyETraining
3)installed the app on my iPhone
4)added all the personal setting there, including personal data, hearth beat ranges, trainer/sensors details
5)saved the data
6)download the my training again on the PC (windows 10)
7) the program start just fine, when I reach the first page, which usually cause the program to crash, it worked just fine as all data were already there!!!
8) tried to couple to the trainer (I have a Suito Elite)
IT WORKS!!!!
good luck folks!!!
Users browsing this forum: No registered users and 37 guests
