Calibration value after screwing the tightener regulator lock screw
isiora
Contact:
Postby isiora » Fri Nov 30, 2018 10:21 am
Hi Elite,
I started the calibration procedure of my Direto because the offset dropped more than 5 points (6503 vs 6509, the value stamped on the sticker).
I had no problem to execute the procedure and to reach to original offset value again, until I screw the lock of the tightener regulator. After this action, the offset value dropped from 6509 to 6505. I repeated the procedure, but I had same result.
What I must do? Do I have I to make sure that the offset value is 6509 after screwing the lock, or no?
Thanks in advance.
Re: Calibration value after screwing the tightener regulator lock screw
Postby Elite Admin S » Mon Feb 04, 2019 2:46 pm
The value must be the same of the original one AFTER you close the lock
danga
Postby danga » Wed Feb 06, 2019 5:46 pm
Elite Admin S wrote:The value must be the same of the original one AFTER you close the lock
Support has advised it should be within 5 from the factory value? So which is it? Exact value or within 5 of the factory offset?
David
Users browsing this forum: No registered users and 63 guests
