I have Elite Crono Mag Speed Alu Trainer. How many blinks?
Re: Elite Crono Mag Speed Alu Trainer
1 flash only!
andiyatsia
Elite Admin S wrote:1 flash only!
i just got the arion mag rollers too and I see that i have the magnet covering, but it almost seems like there is no magnet there? Where exactly should the misuro b+ sensor be positioned as I cant seem to find this information anywhere.
josephmark
- Contact:
With the Crono trainer, setup is easy. Just simple place your rear wheel into the handle assembly, lock into place, and push back so the rear wheel hits the resistance roller. The rider body weight then forces the tyre firmly onto the roller thus creating the friction (resistance). This trainer is also compatible with three third party software platforms to help and make your training session much more fun and realistic.
