Drivo rocker plate
raino.annala@gmail.com
Contact:
Drivo rocker plate
Postby raino.annala@gmail.com » Wed Nov 14, 2018 8:24 am
Anybody built a rocker plate for Drivo?
sebrios
Re: Drivo rocker plate
Postby sebrios » Tue Nov 27, 2018 2:25 pm
I did. Makes ALOT of difference. super super easy to do... just make sure to put the shaft sided, as the weigh of the flywheel makes it unbalanced.
lellinoaereoplanino
Postby lellinoaereoplanino » Tue Nov 27, 2018 4:26 pm
do you have photos?
sebrios
Postby sebrios » Wed Nov 28, 2018 4:47 pm
Sure do man... here are a few. Let me know if you need more info..
total cost... around USD40 or 50
lellinoaereoplanino
Postby lellinoaereoplanino » Thu Nov 29, 2018 11:46 am
wooow :D :D :D :D :D
Contact:
Postby raino.annala@gmail.com » Fri Nov 30, 2018 11:27 am
The image site is giving security warnings so pics may not be visible for everybody, but what I gather is what you needed was simply:
* hhb p204 bearing housings x 8
* axle (size and length?) x 1
* Plywood x 2
* pointy blue air cushion things? x 2
* some bolts and nuts
It seems the shaft is not directly in the middle of the plywood. Is that to stabilize the setup as the Drivo is not symmetric? What did you use to secure the trainer to the rocker?
sebrios
Postby sebrios » Fri Dec 07, 2018 2:08 pm
these are the parts I used:
5 x pillow bearings 3/4 (search on amazon) .. you can easily use only 4. I noticed the one in the middle does nothing..
10 x screws (2 per bearing)
31inch long steel shaft (3/4")
2 pieces of random wood (I used mdf as it was the cheapest)
2 Half Massage Balls
You need to place the shaft a little bit aside, because drivos center-weight is basically where the 2 plastic shells join
hope it helps..
Mary215
Postby Mary215 » Mon Jan 07, 2019 8:07 am
Has anybody built a rocker plate for Drivo? Any reason why I should not build one?
tincaman
Postby tincaman » Tue Jan 22, 2019 10:13 pm
New rocker plate for the new Elite Drivo, scrap vinyl covered chipboard, sealed with PVA
VELCRO Brand ONE-WRAP Reusable Ties to hold the legs down to the board
70mm Inflatable toy balls from the local discount store
I had an hour on it today and it definitely helps with comfort, no doubt at all
Col.Mustard
Postby Col.Mustard » Sat Feb 09, 2019 11:48 pm
Thanks for posting these plans. I'm building one up next week but will be using small Dodge Balls as the air bladders so I can adjust the pressure.
Return to “Drivo & Drivo II”
