Digital Qubo Wireless
joannew
Postby joannew » Sat May 13, 2017 11:30 pm
I have an Elite Turbo Ditigal Qubo Wireless, can I update the firmware on it?
Re: Digital Qubo Wireless
Postby Elite Admin S » Mon May 15, 2017 8:10 am
Can you tell me the serial number of your trainer, so I can check the firmware version?
Usually, the upgradable trainers have a "firmware upgradable" sticker, but the serial number is a safer way to check it.
joannew
Postby joannew » Wed May 17, 2017 11:33 pm
The serial number is SNQ11779.
Postby Elite Admin S » Thu May 18, 2017 8:32 am
I confirm you that your trainer firmware is upgradable.
I've forwarded your request and in few hours you should receive an email with all the instructions to do the upgrade.
Please remember that:
- to do the upgrade, you'll need a pc and an ant+ dongle
- after the upgrade, you won't be able to use the handlebar console anymore
vincent.golle
Postby vincent.golle » Tue Aug 08, 2017 10:19 am
My trainer's S/N is Q13936, is it updateable ?
vincent.golle
Postby vincent.golle » Tue Aug 08, 2017 2:07 pm
Is my trainer upgradeable ? SN Q13936
Postby Elite Admin S » Mon Aug 28, 2017 8:23 am
Hi Vincent
I confirm you that it is upgradable.
To have the complete procedure write to our customer care at real@elite-it.com and ask for it (specify the serial number in the email)
okoktao
Postby okoktao » Sun Sep 03, 2017 10:10 am
Hey,
Same question , serial number is SN: Q 09620
Postby Elite Admin S » Tue Sep 05, 2017 9:08 am
@okoktao
I'm sorry, your version is not upgradable.
PeterC
Postby PeterC » Sun Sep 17, 2017 6:19 pm
I have just recently found this possibility. Is SN: Q 0340 upgradable?
Many thanks
Peter
