Hi there
I used my trainer a couple of days ago and today, when I connect it to the power supply, it makes a constant louder noise than usual and the red light inside doesn't turn on.. I tried to connect in different power plugs at home and the same thing happens. Can someone help me with that?
Cheers
Peter
Doesn't turn on
Re: Doesn't turn on
Probably the electronic board has broken.
Please contact the customer care at real@elite-it.com and explain the situation, they will tell you how to procede.
Remember to add information on the trainer (model and serial number)
scottcole1
Re: Doesn't turn on
Hi, did you get this issue sorted? Just happened to me!
