blutooth
piotr.findura
blutooth
hallo. I can not connect to the ramp by blutooth. telehon and ramp are included.
Re: blutooth
Which error you get in the app when you try to pair the Rampa?
Which device are you using?
Re: bluetooth connexion
Hello
I cannot connect my new Rampa traîner To my Phone S8 using bluetooth. The Phone detects the traîner "RM" but at pairing the message "pairing rejected by RM" appears. The traîner led goes from blinking blue/green to steady blue and rien back to blinking blue/green. What am I not ding right?
Thank you.
Thank you.
Re: blutooth
Don't use the bluetooth menu of your device, or you'll get a reject message.
Run the app and do the configuration there
