Choose your ideal trainer
stevenvancoillie
Postby stevenvancoillie » Tue Mar 05, 2019 8:11 am
I have the exact same problem.
My Direto is one of the older (noisier) models, so I can actually hear the stepping motor in level mode.
I contacted Elite before about this, but they keep saying that the used software is the problem.
Which it is not, as the same thing happens with My E-training, Zwift, Road Grand Tours, Rouvy, ...
This makes training in level mode annoying and doing an FTP test nearly impossible.
gerrad.ferrier
Postby gerrad.ferrier » Sat Apr 13, 2019 11:50 pm
I've been using my Direto for about 8 weeks now, all on ERG mode and have been really enjoying it.
I've just done a 4DP test in Sufferfest on level mode and straight away noticed the fluctuations same as everyone has described.
During the hard efforts there were swings of 50 - 60 watts which is pretty off putting and affected my cadence. Looking back at the data you can see the power trace rhythmically going up and down in a regular wave.
I even tried to set it in level mode on the my e training app and that just made it drop power all together.
Has anyone had a resolution to the issue?
Cheers
stevenvancoillie
Postby stevenvancoillie » Mon Apr 15, 2019 3:18 pm
No, unfortunately still the same problem.
gerrad.ferrier
Postby gerrad.ferrier » Wed Apr 17, 2019 4:19 pm
Hi guys,
I got a solution / explanation from Sufferfest, seems if you get the elite cadence sensor it will improve level mode as the auto sensing of cadence in software affects level mode.
Therese Kirchner (The Sufferfest)
Apr 16, 18:30 CDT
Hi Gerrad,
So I've been reading lots today on the Elite Direto. It seems that the flywheel magnets are what causes this issue. It is very sensitive to changes in cadence and the magnets shift to keep the flywheel spinning smoothly. This gives you that oscillating resistance feeling that you are describing. There's technically nothing wrong with the trainer, it's more of a matter of how to deal with it so that you feel it less.
Having a separate cadence sensor will improve your experience.
Keeping the flywheel speed up will decrease the oscillation resistance that you are feeling. Smooth cadence increases and power changes will probably work best.
Level mode in the Elite app is not the same as our level mode. Ours is based on a slope, theirs is a brake resistance, so that is why you won't feel it in their app compared to ours.
So along with the other suggestions previously given, here are some more. Please let me know how this works out for you, and if you notice some improvement in your experience. Like I said previously, there's nothing technically "wrong" with the trainer, it is just how it works.
Hope that helps.
Candence sensors are only £15 so I will give it a go
