Low power reading
Philiprut
Low power reading
Postby Philiprut » Wed Oct 03, 2018 10:10 am
Turbo Muin
Misuro B+ S/N 16436 (3 flashing lights)
I have been using successfully since January and recently started experiencing dropped power readings.
I replaced the 2032 battery. Power readings are now very low (40-50w at 90+ cadence, normally 140-160w). Readings do not drop.
I have tried to adjust belt tensioner with no change to the power reading.
Any idea what is wrong and how to possible correct this?
Re: Low power reading
Postby Elite Admin S » Mon Oct 08, 2018 9:25 am
3 flashes is the setting for Turbo Muin with serial number from 10000 to 10469.
In your case, you have to set 2 flashes only (serial number from 10470 to 30000).
Return to “Turbo Muin”
