Hi David
Specify the trainer model and the serial number.
Direto calibration
Re: Direto calibration
Hey you guys.
I need some real help with my offset Number. It’s says 6545 but after the calibration it was 6537. So I need to tighten the belt. But I don’t know how. The watts on Zwift are always different to my Garmin vector. It’s annoying. Can somebody help?
Best regards
Best regards
Contact our customer care and we will give you specific instructions
crosby.neil120
hi ive been using my trainer for over a year,but recently having problems cant turn the peddles to calabrate
Hi Crosby
Do you mean that the resistance is always high?
If it is so, there may be different causes.
One of the possible causes is that some dirt is blocking the motor.
In this case, this procedure can help:
https://elitesrl.zendesk.com/hc/en-us/a ... ew-thread-
If this is not enough, the problem may be on the electronic circuit board or the motor screw.
In this case, it's necessary to contact the support:
